| the lower pressure hose. (and at the pump too!) The low pressure hose is a compression fitting onto the hardline that wears over time (and it's facing down). So it can and will still leak. I would think your high pressure hose may not be the problem as it would soak your alternator (mine was). Check the LP line and the wadhers at the pump like TDogg said.
90 Twin Turbo Track Build - jsworks.org for more info!
